nobody wants to buy it so...
ive always thought about using liquid o2 and liquid propane with a super charger, but hiroshima keeps coming to mind!!!
so, apparently the guy was mistaken on something
can an Eaton M90 bolt to the 4.0?
he thought i was talking about a 5.0 when i asked him for some reaons.
The eaton M90 is the twin screw from a 3.8l supercoupe, THunderbird. However there are some guys out there on various blogs that have made adapter plates fo the intakes to make them work on 4.0s hell if you dont to do it, Send me the eaton and Ill do it. The most common swap is the single port eaton onto a dual port 3.8 ofthe 99 and later model years. But its runs like a raped ape. If you cant find anyoen to make the adapter plate, go to the local college and have the engineering class design you an intake on autocad, and then have the machine shop class cut you an adapter out of cnc aluminumumumunm. Awesomeness.
lol, but what did he feed it?
Easy. In Part 1, it was plutonium & lightning to get the juice. End of part 1 and part two was when the Mr. Fusion unit was installed. And in part 3, they used the train to get it up to 88 mph.
I'm a bit of a movie geek. Worked three years at the local Movie Gallery.
actually garbage was the only answer I was looking for, supernerdLOL.
You didn't specify WHICH movie. So I went with the shotgun approach.
More BTTF trivia: Which Texas band appeared in Part 3?
LOL shotgun approach works with pretty much everything. Spit out enough stupid pickup lines and your guarunteed to eventually get laid LOL
Yeah. Don't forget: You're the guy who has two of my quotes in your sig!!
The answer to tonight's trivia is: ZZ TOP!
