- Jul 23, 2010
- Age
- 63
- Pollock Pines Ca
Hi
I am new here I have a 1988 Ranger 2.9L with automatic trans. I have these issues when I put into drive it has a creeking snapping sound coming from the trans. Drive works fine until you let off the gas or going down hill its slipping out of gear until you stop than its back into drive. I was having overdrive issues on the freeway going up hill 55mph it goes out of gear let off the gas put in drive. The trans is fine changed oil and filter a month ago all looks good whats the problem? how can I fix it? also when in OD it slips out of gear going down the off ramps I pull over turn off engine it resets than its fine until it does it again
Is it the 1-2 shift solenoid do I have to pull the valve body to fix it? is there just one solenoid is this something you can buy from Napa Auto Parts?
