1998 & Newer specific Ranger problems.....
1999 Ranger 4x4, 3.0L, 5spd, 4 door, stepside bed.
The oil gauge likes to not work for a minute or two in cold weather. (soon to be fixed)
The 4x4 hubs would only engage for 30sec - 1 minute at a time (fixed)
And thats it, oh and the clutch is going out I think for a different reason (got stuck and someone got in while I was calling and thought they could get it out and thoguht they were spinning tires and smoking em (which I beat the crap out of him for) when it was really the clutch.)
Nice thread idea
2000 4x4, 3.0 flex, auto, live axle
That dang check engine light that keeps coming on haha.
-The EGR system has some flaws but usually the DPFE
-Unservicable wheel hubs/bearings
Reread all the posts today and have some comments that may help ("may" being the operative word here.
Alternator. I noted in both of North44's cases his battery was three or more years old. Just replaced the alternator in a friend's 4-cyl last week...along with the four year old battery Is it possible the alternator is not robust enough to handle a weak battery? Check your battery. If it's weak replace it. Repeatedly asking your alternator to charge a weak battery can cause failure, particularly if the alternator is not heavy duty enough.
Blend Door. Google it in the Explorer forums. The servo is on the top of the heater plentum and the dash must be removed to get at it. There is a little piece of plastic that breaks. This can be fixed from the bottom and involves some "cut and paste." Never done it, but it was an issue some time ago.
Hub failure (late models). First clue may be anti-lock brake light. The bearing fails and misaligns the anti-lock sensor. Had it happen on my '00 Explorer. Tech said there is no telling when failure will occur. Sometimes new, sometimes never.
Tailgate handle. Look on e-bay and buy a metal one. Then keep your mechanism well lubed (chain lube is great for this). Also push in the tailgate as you open. Breakage is caused by the latch dragging against the receiver.
Transfer case servo motor. The motor drives a worm gear with finger contacts on the cover. Before replacing clean them up. Use a pencil eraser to "rough them up" a little. If that doesn't work, take the motor apart and clean the armature. They are not made to be taken apart, but with a little persuasion you can do it. I did it on my '92 Explorer and never had a problem after that.
Locks. Early 2000 - ?? models (the ones with 9-10-11? tumblers in the lock -look at your key to see) use the first few tumblers to work the ignition and the rear tumblers to work the door (or the other way around) - hence the long key. If you don't use the key in the lock once in awhile the lock can get rust and fail just when you need it most. This is also true because the back of the lock mechanism is "open" to the elements. Before you have to use it, spray some penatrating oil and work the lock if it's stuck. Otherwise use it once in a while for grins.
Thermostat. Watch your gauge closely. Over time has it crept downwards on the scale? The original Ford units were made by Bosch. These had a habit of - over time - failing to close, allowing the engine to run cooler than it should. Two problems from this. Heater doesn't work worth a hoot, and the engine does not get out of the cold cycle loop causing your economy to drop by 2-3 MPG.
Can't help with any thing else. As I said in a previous post, my '05 is doing very well so far. Very happy. Do wish the seats were better and had more support. At 6'2" w/out cruise control I wouldn't be able to drive it the long distances I do.
DPFE sensor! Once every 6 months it takes a crap. Inexpensive part and has a 2 year warranty from autozone so i've only paid for one. Still annoying I belive the code is P1501 could be wrong on that.
Yeah I've had the same problem but it doesn't effect anything it just keeps the check engine light on. Only other problem I've had with my truck is just the driveshaft clunk when im getting it going early morning other than that it never happens and I haven't had any other problems with it.
my 2.5l 99 has this unsolved tapping noise.
power steering pump noise
heater regulator plug problem (they rust up and then don't work) i've had mine fixed.
it's a pain in the ass to change intake side spark plugs.
my 99 2.5 has the valve tapping too. i replaced the steering pump and it still whines
and the oil sender acts like original_84ranger posted. takes a minute or so to jump up to normal.
when starting it cold the acelerator acts weird too. i have to let it warm up for about a min or 2 or it wont acelerate.
theres no CEL and iac is new. it always had that issue, since i got it.
no it's not valves on my truck. we've tried 2 different heads it does the same damn thing. the bottom end is all new. i'm thinking it's EGR related.
ohh then it might be another reason for it.
adding to the list: squeaky/clunky front susp. everything is fairly new, but i think the lift spacers have to do with the clunk. the squeaks are common, since my bro's 00 and moms 03 do it.
sometimes the e brake wont disengage after driving on rain and let the truck sit for the night with the e brake.
the 03 2.3 has the check engine and check fuel cap lights on. seems to be something with the evap canister or something like that.
fuel pump died at 114,xxx approx.
on the last shop trip with CEL on and runningh like crap, pouring black smoke i replaced the IAC and o2 sensor
along with both coolant temp sensors.
since that runs like a champ :)
Replaced Control arms
Door ajar light
Replaced both front rotors and boots on both sides
Airbag light is on, and stays on everytime i start my truck ( how do i fix? )
Squeek on left side everytime i hit a small bump
metal clunking noise at idle ( comes and goes)
sensitive brakes in the rain, normal on sunny days
tailgate latch broke
Door ajar light
I hear you on the brakes when its wet out mine does the same thing, Does the airbag light flash at all?
yup, when i start my truck the light will flash about 10 times and stay on
its flashing a code of some sort mine would flash (i think) 2(flashs) pasue and 7(flashs) code 2-7, it would do this a few times and then say on. I found out it was had something to do with the airbag sensor on my passnager side seat. I pulled the neg battery cable and opend the sensor and cleaned it and put some conduting lube in there and now it does not do it. if you count the code on it some guys on here might be able to tell you what it is. Like BigJim
Noisy sway bar mounts.
Replace them with greasable Energy Suspension mounts and you'll be good. (Did this on my 2000 and my brother's 2002.)
