What could go wrong?
bolts shatter/snap when you try to reuse them.
bolts become weak creating uneven pressure on the cylinder head causing it to warp.
Basically as already stated these bolts are torqued down, and then turned a pre-set amount of something like 1/4 turn or 1/2 a turn. Can't remember which as we did our heads two years ago. This as mentioned, tightens the bolts..and then puts a stretch on the bolts which is how they are designed to work. (don't ask me why the manu's do this---that's just how some engines are made)
It's not worth the headache of attempting to recycle these bolts. They are not to spendy (about 40ish or so bucks). The only key thing to do? Is to ensure the threads in the block are fully clean of any crud that would fool the torque wrench. That is why you'll see in the shop manuals instructions on re-tapping or "Chasing" the threads to remove any old gasket crap and rust. The correct use is paramount in order to get a long lasting seal with the block and head.
Do the job exactly how the shop manual states, and you should be in good shape. Try shortcuts and cost saving stuff (such as recycling the bolts) and you'll be in trouble quick!. And nothing sucks worse then having a head bolt snap off in the block.
S-
