- Aug 19, 2009
- Pinnacle, NC
My Rig - 1993 Ranger Super Cab 4x4 with 5 Speed Trans and 30in Tires - Stock Suspension.
Ive been posting on the forum for a while asking a multitude of questions trying to get my Ranger together over the past year and finally getting around to being happy with it.
Here's the list of work since i bought it last year.
-New suspension mounts on rear end.
-Top end rebuild on 4.0 V6.
-Grille Blacked out and Gutterguarded.
-Overhead Center Console out of 2001 Blazer.
-Kobalt Tool Box with Clearance Lights.
-Diesel style Cab running lights.
-3000lb Remote Controlled Winch custom mount behind stock bumper.
-Transmission Swap from A4LD to M50-D.
-3 Custom Mounted Speakers under rear glass.
-Custom exhaust - Gutted cats, single inlet dual outlet Flow-master muffler, 2.5 inch pipe from cats all the way back to edge of body, 2.5 to 4 inch bushing than 4 inch stacks running vertical on cab.
-Rear Window Protector made from Conduit, Rat wire and sheet metal screws.
-20% tint on all windows but rear glass.
-Explorer Rims blacked out.
-Fog Lights mounted in lower grille.
-All running and clearance lights tinted 3 coats.
-E3 Plugs (I personally gained15% increase in MPG).
-Stock right after purchase.
-Overhead Center Console from 2001 Blazer.
-Custom 3 Speaker mounts under rear glass.
-First Snow with Ranger.
-Blacked out Explorer Rims.
-Washed up and detailed.
-Custom Mounted Winch - 3000lb Remote Controlled winch behind stock bumper - PITA to get to when something breaks!
-What she looks right as of 06-12-2010.
-Had to Header Wrap the exhaust pipe and gap it between Gas Tank to prevent any possibility of Heating the tank up (BIG BOOOOOOOM).
Plans to come.
-Either 5.0 Supercharged V8 or 4bt Deisel.
-4inch lift with 33's.
-Running boards or Step Rails.
-Custom frontend with tall grille extended down from
stock through the body colored panel between grille and bumper and other little tweaks.
-Stacks to be powder-coated black and mitered on top.
-May convert to Flatbed pickup.
-Custom mounted exterior Marine speakers in toolbox for outside stereo when working outside with truck.(switchable to cut off during DD).
-Rear slider glass and pop out Quarter windows.
-8.8inch Explorer rear end for Disc conversion.
-Other odds and end things I cant think of right now.
Now that you've seen my build let me know what you think and if you got any ideas let me know. Always open for more ideas.
Plans to come.
