- Jun 10, 2010
I have a 1989 ranger with an m50r-R1 transmission and one day it would not shift into 5th at all and it would shift into reverse but when I released the clutch it would pop out and grind unless I held the shifter in reverse and let the clutch out very slow. I cut an access panel out of my floor pan and removed the shift cover to see what was going on.
This thing (not sure what its called so ill call it the 5th/reverse lever)
Will move into the reverse and neutral position, but will not move into the 5th gear position.
Here it is in neutral
and in reverse
If anybody can help me out it would be greatly appreciated.
and in reverse
