Was going to do U joints on my sister's 2wd ranger today, what a circus. While backing up the ramps to get the rear in the air, she drove off the end of the ramps. The ramps flipped up then collapsed, leaving the rear wheels stuck in the air a couple inches off the ground. A few minutes with the jack and we got all four tires on the ground again. Next time, I backed up onto the ramps!
Ok, finally got under the truck and started chcking things out, hmmm 12 point bolts to the pinion flange, wonder what size. Tried a 12mm 12 pt box wrench, no go. Tried a 13mm box, no go. Tried a 1/2 inch 6 pt socket, no go. Tried a 9/16 6 pt socket, no go.
Now to my silly question. What kind and size of socket do I need to get the pinion flange bolts out? Is this a custom socket or should I be able to get it anywhere?
Truck is a 2001 Ranger 2wd, 2.5 4 cyl, manual trans, bone stock.
Thanks for any info or comments.
Blueman2
Blueman2
