Picture diary of a 4X4 RCD to Dixon Brothers LT Conversion
Those are sweet!
When are you going to put them in? Have you decided on where/how you are going to mount the uppers? Are you going to cage the bed? I can't wait to see it next week!
Those are sweet!
They should be in by Sunday. I am having a local fabricator install a simple bed cage. The idea is that it should tuck around the side and back of the bed. The majority of the bed will remain intact and servicable. I will work out the spare tire mount details later. I am looking forward to the visit as well. Did you decide which vehicle to bring?
I like the idea with the bed. It sounds kind of like what Mike did with his Ford? This way you can still sleep in the truck bed on campouts. I will be bringing down the LandCruiser. Can't wait to take the truck out and flex the suspension!
Bed rack install day 1.
Upper mounts and rack should be complete tomorrow. A rear bumper/tire carrier will be added at a later date. At this point, it appears that bumped and strapped, the rear end should have 19+ inches of travel.
Got the truck back today. Bed rack installed and tire cable flipped so that I can temporarily secure a spare to the back of my bed. Now I need to get some limit straps so that I can go out and field test the suspension.
Looks Incredible!!! Get some limit straps at SDHQ in gilbert! You can order them online and im pretty sure we do Free Shipping in state.
http://www.superduty-hq.com/sdhqquadwraplimitstraps.aspx
Or you can call, 480-633-2929
Tell them I, Jason Holmes, sent you.
Sorry to totally plug my own shop but, i thought it might help.
Thanks, for the heads up. I ended up buying some Beard straps locally at Bugs n Buggies. I may end up buying an extra set of SDHQ straps if I decide to double strap the rear end. I like the fact that your straps are quad wrapped. I wish that there was an SDHQ here locally. I have browsed the store a couple of times when I have been in Phoenix.
Unfortunately not. I am trying to figure out how to scrape up a few dollars to get my front end regeared to 4:88 as I want to get my 4X4 back. Once that is done, I will need to get a rear tire carrier/bumper built. Then I will need to do what most people do first - build a proper front bumper with a skid plate. I did pick up a couple of 20mm ammo cans that I plan on using as tool boxes to either side of my spare at the back of the bed. One needs some rehab work but they should work out great.
I have a bolt on rear bumper/tire carrier. Bolts to the last bed bolts and where the tail gate goes, then the tire goes in and a strap holds it. I'm moving to Phoenix soon if you want it.
so is your bedrack still going to work with the rear shocks in i was loving the rack
