- Dec 9, 2008
Ok. Here's the situation:
Truck won't even turn over. Turn the key and the dash lights come on briefly as expected, but the engine doesn't even try to turn over. I've had some issues with this over the past few weeks, but nothing serious. It eventually started. Not so today. Came out of the grocery store, wouldn't start. Puddle of fluid underneath. This isn't good. I had it towed home and checked it out. I'm seeing basically two problems:
There's a cylinder underneath the truck that I suspect blew out, at least there's fluid on one side of it. I'm not sure if this is the slave cylinder or not.... I've heard varying reports as to whether you can get at the slave cylinder on an 88 ranger without dropping the tranny or not. This is external, black with black hoses going into it, and a small tag on it that says (I think) Flow. It's not hooked onto the transmission as far as I can tell. This may not be the slave cylinder, especially since the other thing I noticed when I popped the hood was fluid under the hood. Poked around and the cap on the power steering reservoir seems to have burst. It's still on, but it's partially lifted up and the catch that would hold it closed is broken. Looks like there was some kind of surge in pressure and blew the cap.
All of this strikes me as A Bad Thing(tm).
That's the information I have, I took pictures of the relevant parts, and can post them if they'd be helpful.... mostly I'm looking for 'where do I go from here' information.
