no drain plug??
04edge
10+ Year Member
so i go to change the fluid in my t-case and whadda ya know-- no drain plug?:stop:--guess i'll have to vac it out:bad:
May want to check under the round balancer on the lower left side. That is where mine was on my 2001 ranger.
thanks for the info!!:icon_thumby:
do you need a puller to get balancer off----or just 4 bolts and thats it,
It's just four bolts.
It's not meant to be difficult. This is maintenance.
I never did truly understand what the point of that balancer was. It didn't weight that much.
It doesn't seem to do THAT much, but it's a harmonic balancer, much like the one on the crank. Big mass isn't important. Big moment of inertia compared to the shaft it's balancing is.
