- Mar 17, 2009
- Columbia, SC
OK, I opened a big can of worms and looking for a little information. I have a 88 bronco II and after doing a little looking around on here I decided it would be cool to put in a newer dash. I got a dash from a 93 explorer and proceeded to do the swap. After buying two books and pulling half my hair out over the wiring, I thought I was good. Well my gas gauge did not work, my overdrive did not work, so over the winter the bronco sat. Well I thought about it and decided to get a wiring harness from a 94 explorer to swap in the bronco. After spending 7hrs at pull a part I had my treasure, there are a few items that I am unsure of…one is the anti lock brakes. It would be cool to have it on all four wheels, I know a rear end swap would not be that hard to do but what about the front end? And while I am swapping the front end I might as well make it 4wd. The harness came out of a 4wd so it would be just plug_and_play as far as the wiring goes. I did some searching on here and could not find much on it, of course my searching skills might not be that great. Any information or a point in the right direction will be greatly appreciated. On e other question, going from a 4 door to only using 2 door for the power windows and locks do I need to do anything special…like need to have the switches plugged in to the 2 rear door plugs for the windows to work?
Thank You,
Louis
Thank You,
Louis
