- Nov 4, 2007
- Age
- 53
- Crookston, Mn.
I think either my fuel injectors, or ignition module are causing my 87 Ranger 4x4, 2.9 engine to run rough..
It runs rough either cold or warm..
I've replaced all the sensors, except for the ignition module.
I've put a 89 Ranger computer in, thus eliminating the EGR system.
Have installed new spark plugs and wires.
Replaced fuel filter, fuel pressure indicates 34 lbs. at idle and a little over 40 lbs. at higher RPM's.
I've got good spark, all electrical grounds are good, engine has good compression.
There aren't any vacuum leaks, anywhere.
I added three 12 ounce bottles of Techron to the gas tank and it's still running rough.
Can a ignition module cause it to run rough when it's cold or warm?
I've read in other posts that a ignition module usually fails when the engine is warm and the engine will stop and start again when it's cooled off.
The engine doesn't stop or anything when it's warm, it just runs rough either cold or warm, like I've already mentioned.
Anyone have any ideas to figure this out, as to what's causing this problem?
The only two things I haven't replaced, yet, are the fuel injectors or the ignition module?
The three 12 ounce bottles of Techron added to the gas tank, should clean up the engine's fuel injectors, if that was the problem. Shouldn't it?
