- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Total Drop
- few inches
- Tire Size
- ~30"
I'm looking to do a swap that I know is kinda backwards from the norm, and am hoping to pick y'alls brains a bit.
I have a good 5K mile 2.8 in a dead 84 Ranger. I have gotten a line on a good 86 Ranger with a dead 2.9 for $500. The 84 is a LWB, the 86 is SWB, and both are regular cab. Since I have my 2.8 set up with Duraspark II the wiring will be just like swapping in a V8 that shouldn't be a problem. In fact I'll probably just get a universal wiring harness and do away with nearly all of the factory wiring.
Q1) If the two were both LWB trucks I'd just swap the tanks, but this is not an option. What do I need to do with the 2.9 fuel system to feed the Holley 4bbl on my 2.8? I have considered a fuel cell and but it is an extreme last resort.
Q2) My understanding from the tech library is that both of these trucks use the TK5 transmission. As such I should be able to unbolt my motor from one transmission and have it bolt up directly to the other right? With the same transmission and practically the same motor the flywheel and clutch from my 2.8 should work on the 2.9 TK5 shouldn't it?
Q3) If this truck has ABS I want to keep it. That said how did the abs on these trucks operate was it mechanical using some sort of pressure differential or was it electronic? If the latter is there a way I can keep it while removing the engine computer and most of the wiring?
Q4) ... I forgot but when I remember it I'll add it to the list.
