- Feb 8, 2009
- Omaha, Nebraska
so your "yellow" wire on the factory plug side of the harness is getting 12v constant now after replacing that fuse then? if thats the case then you should be all set and i would remove the tap you put into the cigarette lighter, or buy another power outlet and run the wire you added to the new outlet. then youd have an extra outlet and all of that work wouldnt be wasted. wiring can be very frustrating until youve done it enough to become confident (usually confidence comes with having lots of problems and then learning how to use the basic testing tools to solve them). keep working at it, i know youll get this thing licked!
ya you would think i'd be good........
i'm getting over 12v of voltage all the way up to the head unit (tested it at the plug that inserts into the head unit on the back) and still my head unit won't turn on.
i don't know what else to do, like i said the fuse on the head unit is not blown and i don't know any other way of figuring out how to work it any other way, not sure i'm exactly comfortable physically taking apart the head unit, but i don't want my money to be wasted on this, as i somewhat like the head unit
