Redlineracer12
- Dec 21, 2007
My 96' 2.3 has been slowly leaking oil for a long time now, but now that I'm driving it (gf's ranger
) I'm looking into fixing the leak. I'm thinking it's leaking where the oil pan meets the block towards the front of the engine. Everything from about the crankshaft pulley down is wet with oil, is there a seal up there that could be leaking? It seems to run down on the bottom of the pan and pretty much spreads all over everything under there.
I've read that the engine needs to be removed in order to remove the oil pan. I would rather just leave it in there if it's possible. If I lift the engine part way out of the mounts and support it temporarily will that give me enough room to get the pan off? Does anyone have any advice on the project?
I will also probably replace the timing belt, temp sending unit, and possibly the waterpump during this project.
TIA
TIA
