Degreeing a cam
Ozwynn
If you didn’t bleed for it you don’t deserve it
Berrien Springs, MI
MI - USA
whats the purpose?
Making sure it is installed correctly, mostly. That there are no errors in the sprocket keyways or pin. To a lesser extent, you can move the intake opening point around for tuning purposes if you have a multi-index sprocket.
The purpose is to make the valves open at the right time to make maximum horse power...
Hey long time no see BDAB, good seeing you!!!!:icon_thumby::D
yep, I am back, however I am not going to call anybody out anymore, no matter the nature of the personal attack ....... I am not even going to ask if somebody is retarded anymore...
is it necessary?
It's okay I am still retarded lol!!!:icon_thumby:
is it necessary?
It really depend on if you want to spend the time getting every thing set up for maximum performance but this is not necessary unless building a race motor...
kinda like clocking (indexing) spark plugs then?
is it necessary?
Not really. The timing might be a few degrees off from the machining process, but unless you're squeezing everything you can out of the engine, it doesn't really matter. I guess it would if it's an interference engine, and even then it'd have to be fairly far out.
I just helped a friend put a new cam in his J10's 258. We never bothered degreeing it. Fired right up, broke it in, and has put a good 6000 miles on it since. No issues.
Helps to find true TDC. after cam change from stock grind to more aggresive grind.
