RangerSVT
Oct 09 OTOTM
ASE Certified Tech
Boosted (Not Stock)
- Mar 15, 2009
Does anybody know where my 4WD went??
Well, I found out why I lost 4WD when I was out at Turkey Bay.
I find it wierd that I didn't blow a u-joint yet (have 228k miles on truck, original joints)
Well, as I took my diff housing out, I noticed I had excessive pinion side to side play, and figured I stripped my R&P gears, so I guess I got lucky there, but instead of my R&P gears, it was my spiders, but I still had pinion play. So I pulled it apart and found my bearings were toast...So I now need to practically rebuild the front end again...I have a spare carrier that I was goin to use the spiders from to replace them, but when I went to install the spiders, the splined spider didn't fit into the carrier
So now I have to pull my Ring gear off, and install it onto the other carrier I have, along with installing new carrier bearings, pinion bearings and setting up the axle all over again
So I started cleaning up the parts and guess what else I find...
Anyone see anything wrong with this picture
I checked all the stores (AZ, Advance, Oreilly's), and Oreilly's said they had it in stock for $13, but when I got there they had to order it as no store stocked it and it would take 4 days to get in
Sooo once I get everything back together (and spending close to $100, which I would rather spend on my SAS, I will be ready to go back to Turkey Bay with 4WD again
SVT
SVT
