- Mar 20, 2009
- In the Middle
My first swap was using a 5.0/AOD from a '92 T-Bird into my '97 Ranger. I had the whole donor car to work with, so there was no searching for extra parts or mix-n-matching things. Everything went flawlessly and worked perfectly from the first start up.
Now I'm wanting to try another swap..., but it will be pieced together.
The truck is a '93 Ranger with a 4.0 and an auto.
The engine I want to get is a 5.0 from a '99 Explorer.
The transmission I want to use is an AOD from a '90 SuperCoupe with a fresh rebuild.
If I want to keep the distributorless ignition of the Explorer and still use my AOD, can that be done? My brother has a QuarterHorse system from Moates and says he can turn off the transmission and emission functions in my Explorer computer so it can work with the older AOD. Does this sound right?
Otherwise, I find a harness from a Mustang or another T-Bird and use that with a distributor? It just that easy?
