well it appears i didn't get the new springs in yet.
they wrecker never got them out til noon
then i had fun with just about every nut and bolt on my truck being siezed like crazy
and the spring bolts were stuck in the bushings (we got one out in about 45 min and decided this was stupid when the second bracket broke tryin to pound em out as we dont have a torch
so i put the new u bolts in and threw a hose clamp on the broken section of spring to keep it from wackin anything
tomorrow i will drop the leaf off a spring service and have them replace the siezed up bushing
then ill get some grade 8 bolts and locking nuts and tear it all apart again (should b a lot quicker this time.
i took pictures and had another look at my diff to see how it was holding up and to my pleasant surprise the pinion bearing is perfect the problem is a couple driveshaft bolts had loosened a little bit enough to make the DS have a tiny bit of play and after a quick tightening its back to perfect!
however the u joint has a little slop not much but its there.
pictures!!!!
ok pictures are taking a while cause there is a video too so ill just postem later
