easiest way to change fuel filler neck?
94ranger#22
Havasu
whats the easiest way? drop the tank? or pull the bed?
thanks
if you are just removing the filler neck, you might be able to get at it without taking anything off. If not +1 for removing the bed
I agree. With a bit of spray lube and muscle you should be able to wrestle the neck free without removing anything else.
If you are going to all that work take the bed off and replace your fuel pump!
yea i ended up just pulling the bed, had evrything done and back together is less than an hour.. thanks guys
