Where to put the SWITCHES
Here's my buddy's... 5 on the a-pillar...(best pic I got ATM)
Here's mine....on the front of the shorty console...
If you convert/or already have a cubby hole next to the passenger side bag switch, hidden up in there works too. just give the cubby a slap with your hand and that plastic just pops off. There's 3 7mm screws securing the bracket, then drill your holes on the "roof" of the cubby, mount your switches. BAM! hidden, somewhat easily accessible switches. And if you take the switches out, won't leave an ugly ass hole somewhere and doesn't look tacky with switches mounted.
I plan on making a switch panel to mount in the little cubby hole that you have when you install an aftermarket headunit, ill be sure to post pics when its done
i used the overhead console for my switches came out ok but not to much room to play with
I decided to put a radio in before offroad lights, so ill keep this in mind. Thanks
I put my switches in the place the ash tray would be . . .pics as soon as possible
this is were i mounted mine, that way i keep all the light controls in one place
In my 92 under the headlight switch there is a blank panel.
Thats where i mounted my starter button, my radio switch, and my amp switch.
They all look nice. Pics?
Ignore the mess of wires on the left, I kicked my CB the other day and knocked it off, and i had to pull some slack in the wires until I got it mounted back up. Its all cleaned up and purdy now...
It is also properly centered over the top of the cupholder deal on the floor, the angle the picture was taken makes it seem like its off to the right too far.
If you have the radio and heater delete option there is room for gauges and switches. Sorry, this is only pic I have.
