- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
Thats not correct at all. If your draglink isn't parallel with your trackbar, you most certainly will have steering issues on a solid axle too. Absolutely no different than having your tierods parallel with the beams on a TTB (well, finding proper steering corrections for a TTB can be tougher being everything out there is mislabeled, maybe that's what you meant?)
I've got no issues with uptravel... I can forklift a tire right about 40". Again I say it is possible to exceed that with a solid axle up front (you say 48" combined flex now), but by that time you're gonna be flopping around all over the place if you don't put a stiff set of swaybars on it that you'd have to unpin every time you go wheeling (I know, I've driven Jeeps with floppy suspensions myself, they don't handle so well when built for massive amounts of flex).
