I wanna learn stuff everyone can comment
BlueLighting1999
Des Monines,WA
Okay whats the easy ways to get better handing and Steering?
Whats also the hard but best ways to get more Handing and steering??
PLease comment with anythin and everything you know! Thanks!:headbang:
what kind of rig are you trying to improve handling on? trail or street? are you looking to be able to go fast and turn sharp or are you looking to eliminate wash board floating these trucks are famous for?
Go rancho steering stabilizer, works on and off road to make steering easier, better tires always help, match terrain and tires. all terrain tires work kinda ok everywhere but dont excel anywhere, street only for street, or offroad only for offroad, common sense
Depending on how old they are, new shocks make a big difference. I can take corners pretty briskly and it wont roll like a lumberwagon like my friends 98. Check your tire pressures too. Here in south central minnesota lately, the temp has varied as much as 30 degrees in a week or two. My tire PSI was as low as 12 PSI on the coldest days making for squishy handling and when Id fill it up, and then it'd get up to about 35 or so degrees, my PSI expanded up to about 35 PSI. Tire pressure is a fundamental yet oten overlooked component of your suspension. I know a difference of 5-7 PSI is noticeable with my tires, and I have Goodyear Wrangler 15"s.
its kinda hard to put a steering stabilizer on rack and pinon steering.
