liftedranger
- Jan 16, 2010
My truck has a 20 gallon tank, I completly filled it up. Reset trip odometer I drove 50 miles and I had half a tank. 50/10=5
except the hieght of your tire cant be used to determine the distance you travel if im correct youd have to measure the distance around the tire and compare against stockyou can just do the math...
if your stock tire is 28 inches tall...and you have 33s now...thats an 18% increase...
soo if you go 100 miles on your odometer...18% increase, you actually went 118miles then use that as your miles..yadda yadda..gas mileage found
unless you want to spend the money for the tuner so that its permanently fixed
