At the most i would go 2000. Also plan on running a tranny cooler with a higher stall converter, they build up a lot of heat as was stated above.
got the vac modulater hose attached to my intake manifold. I am not sure if thats how it goes. I figured it was an open vac source for it to be hooked up to. Maybe it goes to the carb?
and when i shook it around it sounded like something inside was loose. I figured it was broke internally
