2.8 or 4.0
84stealthranger
murphy north carolina
well the title says some of what i wanna kno lol should i find a 2.8 and rebuild it and drop it in with some add on parts like the dura spark and a few other things? if any ideas on add on parts post em up. or should i find a 4.0 and swap it. btw this is my DD but i dont need it to get to work so time isnt really an issue but what would be the best for a good relieable truck also im gonna wanna put a 5 speed in just for the extra gear and do the 4.0 clutch swap if i do a 2.8 any suggestions on doing any of this. :icon_thumby:
the 2.8 isnt a bad engine but it just doesn't make alot of power. the 4.0 would be a real nice swap but there is alot of wiring changes that need to take place. You could build up a 2.8 for a lil more ponies but that would cost alot more. I'm kinda toying with the same idea you are having and am leaning towards a 3.8L v6 and using a throttle body injection wiring harness that "pretty much" just plugs into the old 2.8 harness.
I don't think the 2.9 efi is much different from your 2.8, but when i went to a 4.0 i noticed a huge difference, but what i didn't like is the notorious m5od.
if time and money is no object, you'll like the 4.0 more, its not a bad cruising motor and seems to drink less than the 2.9..but that could be because I don't have to floor it up hills :D
4.0 is also a good towing motor...I haven't found out yet because of the m5od
When doing to 4.0 swap I'm also told that you have to put the 4.0 dash board in your truck to make it easier to wire up.
might be better if you can find an older, carbed 289/302 for your swap. more power, no fi add-on's to do (gas tank, fuel pump, etc.), no dash swapping, etc. and, iirc, there are tranny adapters for the swap. just a thought.
If you put a 289/302 in front of a ranger tranny, you can estimate the life of the tranny in minutes (I'll give 10 min. at most).
haha so 289 is a bad idea unless u swap a tranny also i kinda dont wanna have to swap a dash. is that 3.8 from a mustang v6 i think those r in the ford vans too what ever there called lol. Dangerranger what did u do too ur 2.8 i kno u have done alot ive seen ur thread too. what r the chances of finding a 2.8 and how much would i be spending to do a full rebuild
the 2.8 isnt bad with a few modifications. Mine has been turning35's and 40's for the last 4yrs.
well thats good to hear ive never had a problem with it starting ever just once but i think it had a vapor lock it was hottt that day if i could find a 2.8 to rebuild i would work on doin that while driving what i have then swap em out but i think its a better idea to take my time on something like this. from what ive seen in the 2.8 forum thread this is a good motor i think ill go with the 2.8 rather then the 4.0 i dont need more power haha. anyone kno anyone else selling one ha
Actually a common transmission for a V-8 swap is found in the 83-84 RBV's... the C-5 which is pretty much the same thing as the common as dirt behind a V-8 C-4. I have a C-5 stashed away with a V-8 bellhousing off of a C-4 for my pending 302 swap.
I looked at rebuilding a 2.8... it doesn't cost much more to rebuild a V-8 (or I suppose a 4.0 if you prefer) Wiring will be a challenge with anything fuel injected but the sensors for the dash (oil pressure, temp and amps) will still be the same.
All my engine has done to it is a high volume oil pump, new gaskets, and a TBI system off a 3.8 liter engine, just needs a fuel regulator but runs and drives but is getting to much fuel, go figure though and has 180,XXX miles on it, came out of my dads truck. I will say its better then the 2.3 liter I had in it.
To keep it simple, rebuild a 2.8.
The tranny mine has is the Toyo Koygo 4 speed, orginaly had a 4 banger in front of it, my truck was made the first year it produced. I personally have never seen a C4 in a ranger, not saying they werent made with them.
yea i think i have that same tranny its a 4 speed i have a parts truck with a 2.3 and 4 speed and transfer case idk if im gonna use it tho. ill take a look at the junk yard to see if they got a b2 or ranger with a 2.8 or maybe something else with a 2.8. i might go crazy with this motor and save money and build it as i get more money get some things that i seen in the 2.8 tech section
Mine is technically a C-5 out of a '84 Bronco II. Like I said they are very similar to the C-4, there were some differences in the valve body and had a locking torque converter. They didn't put them in very long, and they were before automatics really started catching on in the mid/late 80's.
c_5
if you dont mind an a/t find a c-5 it will bolt up to every thing up to and including 302
