need help truck wont start
7111127
Coweta Oklahoma
been running good for few years christmes eve i took it out drove it about 1/4 mile it died
found a bad ing coil and hole in gas line fixed them
still wouldnt start
so i replaced disturber cap rotor spark plugs wires etc i got good spark and gas still wont start
any ideas?
1984 bronco ii 2.8
well if you have spark and fuel you may have messed up the fireing order.
fuel firing and timing all you need just make sure its geting all that and if it has a cat gut it
cat is short for catilitic converter, its and exhaust gas emissions component. if you look under the truck it would be the first larger chamber before the muffler in the exhaust system. but honestly i dont think it would cause the engine to not start. unless you had a massive lack of power before that. also if you have emissions testing removing or hollowing out the cat will cause you to fail. not to mention its agenst the law. first thing i would do is make sure that you have fuel, (remove the air cleaner and look down the carb then open the throttle plates to make sure you can see fuel squirting down the intake. next check for spark, if you have both make sure the timing is correct.
last month it was at a shop timing was right i get fuel for sure if i try startin it for awhile and it will fluid and the top of the carb will be wet with gas
im looking at a wiring diagram could it be a relay?
i have a EEC Power relay that runs to the TFI Ignition Module
if it was there would be no spark, but it would be more likly that your tfi ignition module was bad more so than the relay. but if you have spark that isnt where i would look. if you dont have spark i would check it out.
well I pulled the 3 plug wires on driver side and checked for spark they got it I didn't check other side cuz they should have it. could it be a sensor? cam sensor or something idk where it is ifnu think that could be it lmk where its at
no i dont belive it would be a sensor. ok so does it try to fire up when you crank it over?
and to awnser davidkfannin's question you would start by puting number 1 cyl on TDC compression stroke. once there pop the distributor cap off and see which direction the rotor is pointing. reinstal the cap and put #1 spark plug wire on the closest terminal to where the rotor is pointing. then in a clockwise ritation place the rest of the plug wires as follows: 1-4-2-5-3-6. then you will want to losen the 1/2" bolt that holds the distributor in place. start the engine and turn the distributor till the best idle is obtained.
now if you have a timeing light you will want to set the timing to about 10* before top dead center.
motor just turns over don't fire or act like it wants to start
ok have you checked the firing order?
I took the old cap off and marked on paper where they was turned the key over making sure rotor turned put new rotor on then new cap pluged wires in same place
lol if I gota do some diff let me kno
well honestly all i can think of is that the timing is wrong. i mean as long as you are getting spark and fuel it should fire. the only other thing would be compression.
