Ok....first off, merry christmas.
secondly, you shoud probably get off your high horse with that engineering degree that means jack shit and listen to some people like JohnnyU and others like myself who have learned from experience. (some of us the hard way). Also take your balls out of your hand bag and dont be a cry baby claiming personal attacks, obviously you're somewhat smart, so you should realize it has nothing to do with you personally, its the fabrication of your build.....
I, nor anybody else here has any personal problem with YOU.
all of that aside, you're argument about the trac bar mount is over burdened with fallecies. It doesnt matter if you use 1/4 or 3/8... I seen the picture of your welder... trust me... its not penetrating the 3/8 any better than the 1/4.
Your new mount is neither stronger, nor improved by any significant value.... it is heavier though...
Secondly, the picture of Nobody's old truck is either missing, or you cannot see that he ran a brace from the trac-bar mount, to the engine x-member, although even without that brace, the way it is mounted, spec wise... does distribute the load different and better than your mount.
moving on to greener pastures.... the city called, they want their stop sign post back.... come on man, that shit is janky. Did you really butt-weld that 90* without any sort of gusseting? You sir, are braver than I.
I am however impressed with your little design you made in the rear axle truss window thingy... no bullshit.... I'm serious, that is pretty good.
I will stop here for now unless you would like to continue our discussion.
Feel free to find pictures and posts about my truck, you will not find much to give me a hard time about, and if you do.. thats ok, I wheel harder than you anyways.... even in your dreams.
Happy Kwanzaa.
