LED dash bulbs and hvac install
parson2008
Wisconsin
i want to go with blue led's, but where can i order them and how do i do the hvac bulb?
hvac bulb is accessed by removing the radio surround, then removing the hvac control panel screws. The bulb is in the back of the panel. Red lights may get you in trouble with the law. Exterior reds may be illegal in your area.
Search the net for "194 led lights"
Sorry, just re-read the question. Just get the same exterior bulb lights you have now, and plug them in. Be careful of the color. Specific light colors (red, blue, or yellow) may be illegal in your area.
superbrightleds.com i think is the site for those. good luck with your install.
I've gotten all my led lights from superbrightleds.com. I've replaced the third brake light bulbs, license plate bulbs, brake light bulbs, and all the dome lights. You just want to be sure and get whatever color bulb that the lens is. red tail lights = red led, clear lens = white led, etc. etc. If you are wanting to do turn signals you will need to get a load resistor though so it doesnt flash super fast. Blue works great though in the dash and hvac. Legal wise, you will be fine. Just not exterior blue and red in the back only.
He can also use the turn signal they sell that is designed to work with LED change outs.It just connects directly into your old flasher relay!.I had the fast flash and their turn signal flasher worked perfectly. I just changed all mine out.The part number for the flasher is EP27L on www.superbrightleds.com . I live 10 minutes from em so I avoid shipping lol.Got my stuff 2 hours after ordering. :icon_hornsup:
I saw that on their site for the first time a couple weeks ago. Im not thinking about changing my turn signals.
