is changing tire size a problem?
some rangers came factory with 265/75r15s. and the 215 to 235 depends on the aspect ratio. a 215/75r15 is the same size tire as a 235/70r15 just a little wide(by 20mm from bubble of sidewall to bubble of sidewall.) thats what the first number is the width in mm's.
My truck seems to ride higher with the 235's :dunno:
you are forgetting the second number is really important to determine the height of the tire. you could have gone from a 215/75r15 to a 235/75r15 in that case it would be taller
Exactly my point.
