Brite Box
ajmiller
Hubbard, Oregon
does anyone have this? can i see pics? was wondering if it actually works good. maybe considering getting one
thanks
are you looking for more driving light or just for more lights to flick on when on a dark road with no other cars?
just driving...im already getting hella 500's i just wanted better headlights
your best bet would just be those headlights you got and some auxiliary driving lights mounted down lower to light it up wider
Yea, I have some Hella 500 fog lights that are street legal because they have one of those metal shields over the bulb, I have them aimed a bit below the normal headlights and it helps a lot
ya im just gonna get a light bar and mount 500's on them.
thanks guys..
be sure and adjust them properly so they dont blind other drivers
you don't need the bright box... all it does is leave your low beams on when your high beams are on. You can simply wireup a relay between the high and lows for the same effect.
Look at the high beam upgrade then read the bright box thing
http://www.therangerstation.com/tech_library/hibeams.html
I did this on my trucks
I haven't in the 2 years I have ran it. The only problem I would think you could have would be heating up the headlamp too much with both running but I haven't had a problem there either. Wiring shouldn't be an issue because the high and low beam have seperate circuits and seperate wires going to them. and the relay bypasses the high/low beam switch in the cab so that shouldn't overload.
