help please !!! prerunner my bronco II 1987 4x4
on the mcneil racing .... do you know whose or anything about that truck that thing looks sick clean pait job also
Wich one? The yellow one or the blue/white one?
The yellow one has the 00 Explorer conversion glass up front. The blue/white has the 03 ranger front glass.
The solomotorsports B2 has been my inspiration on my truck.
the look of the green one it is green white ... i think a little blue.. wow the autofab suspention is expensive
... duff or skyjacker??
ok ..i will check this out .. y do you have 2 different fiberglass one for the front and one for the back ??if you had to pick one who would you pick duff or skyjacker..
I prefer the Hannemann style front glass over the others. Autofab has some listed but again not crazy about the style.
No experience with either kit. I built my own.
i figured that is what it was clean .... do you have a pick of the one you like
what about mcneilracing .. front and back fiberglass...james duff #5023 Stage 1 Suspension, Bronco II 4wd 3" lift $599.00 ... 33" bfg mud terrain . hey what about rims .... do you have any websites ...
I under estimated the height. Front and Rear to the rocker is 24".
Hey now the rims are going too far. It's your truck. I'm just letting you know what's out there. I'm not building it for you.
naw bro im just feeding ideas in my head. i have an idea of what i want just if their is anything out their diffrent befor i do stuff to the bronco II sorry if it seems like your bulding it ... but your just giving me a lot of ideas i apreciat it .. what is the diffrence of a 4" stage one from skyjacker and a stage II ????? besides the big price jump....
your not building it ... i need ideas i like some rims but it is hard to find some that fit the bronco II i love these rims and i want them but ....
http://eastsidecustomtruck.com/i-125200-mickey-thompson-15x8-classic-lock.html .. the only problem is how to get them on i dont think i can get them to fit or work ..
my bronco II 1987 the date on the door is 8/86 does this mean i have to change the drive shaft ???? >NOTES:G2. On 1985-90 Bronco II’s Equipped with a ‘Tulip-Type’ Rear Drive Shaft, the Drive Shaft MUST Be Changed When Lifted 2” or more. G8. Power Steering Models Only. G27
The difference in the stage II is the extended rad arms. I don't see why those rims won't work. I've got 15x8's with 4" backspace. No problems here. Likely have to change the DS. There are ways to do it on the cheep. Explorers front and cut the double cardian part out.
have you herd anything good or bad
about rough country 4" lift ???
