- Oct 1, 2009
Ok well i found out that my truck has 4.10s in it and does not have a limited slip and its a 2004 xlt so has 28 spline axles
the yukon duragrip has the clutches in it and are rebuildable. I was told it uses the same parts and is just like the eaton limited slip?
Or the auburn high performance limited slip which is the cone type and not rebuildable. Everyone tells me by the time it does wear out i more than likely wont have the truck anymore?
So between the two which one should i go with? Or is there something else you recommend over the two i mentioned let me know, thanks
