Boggin, not to put you down bud, but I coudlnt get a part off my truck and keep in mind Im 29 and been working on my trucks since I was 16, $ montsh ago I was doing the trannsmission and I pulled like you said wiht no results. I was pulin the wrong way. Double check before you start cutting stuff.
UPDATE:
i got the steering stabilizer unhooked, the pitman arm unhooked, and the shocks unhooked, coils are next, and the worse thing is the trans crossmember is attached to the rad arm brackets, so i guess i gotta support the trans with a jack to get all that off?
ok thank you, i dont have to work today so ill be going at her after school and ill post what i see thenYou shouldn't have to support the trans, there are two more bolts in the trans crossmember that go through the top of the frame. Just check that they are still there if so then they will support the trans fine no jack is needed
