- Feb 8, 2009
- Omaha, Nebraska
Sounds like it was drilled twice. If that hole is oval, go to junkyard and get an oval body plug. In your truck, look on the floor behind the seat on the driver's side; you'll see a black plastic oval body plug. Score one of those, then just trim the hole to fit with a razor knife or aviation snips.
it's not perfectly oval at all.
very irregular shape. and not sure there is a floor drain bigger than the hole to cut to fit...
thought about using pond repair foam (was suggested) or like waterproof insulator foam... but not sure how it would react with the metal or the bedliner material
