do i need abs block on frame
sluginxlt
i have a 90 ranger and that block on the frame is always leaking and getting worse, and im in the middle of an sas so i just redid all my front hard lines and hoses might as well do the rear. can i just run hard line from master cyl back and get rid of that block? my abs is messed up anyways because i put a chrom diff cover on the back and the abs ring rubbed on the cover and messed up the teeth.
RABS rarely works correctly anyway.
But you MIGHT want to change out the rear wheel cylinders.
The Non-RABS trucks use a different size rear cylinders.
so would i have to change the wheel cylinders or will they work. i put all new brakes on the rear when i swapped in the 8.8 and i dont know if i got ones for abs or not anyways.:icon_confused:
