question on clutch line on a 89' 5 spd
85DANGERanger
franklin, in
im trying to push it into the slave cylinder, but it wont stay in there. its not in there tight and it leaks. its a brand new slave cylinder. what is the problem?? is there more to it then just pushing it in?? am i missing a piece?
What kind of slave cylinder?
Plastic or aluminum?
The '88-92 Rangers are supposed to use an aluminum slave cylinder
with either a Red or Black coupler.
the '93-up "plastic" slave cylinder uses a yellow or "gold" connector
and this is not compatible with the earlier line.
AD
theres a little pin you have to drive in after the line is pushed in to the slave cyulider.
AD
i guess i should say its a bronco 2. it has the black connector.
Presuming that the line has a black connector also (they fade to a purplish color)
the compatibility issue I mention isn't your specific problem.
However you should look up inside the female coupler to see if the
barb teeth that retain the male couple are missing or bent.
AD
AD
i looked in there, the barbed teeth are still there but they do look pretty flat.
