99 4x4 stock measurements?
96Greenster
Rio Grande City
Can somebody help me out with this, I need the stock measurements for a 1999 4x4 extended cab 4dr, 4.0L Auto trans, I trying to find out how much torsion crank the previous owner did. I have some 31x10.50x15" on it also, but doesnt matter too much. From the edge of the rim to the inner fender would be ok... Thanks:icon_thumby:
wonderng the the same thing. I recently did my t-crack, 2in bl, and 35's. And i want to know how much higher than i am over stock.
I'll measure mine in the morning, same except I have a 3.0L... hopefully doesn't make too much of a difference. I have No crank and 31's sitting on 15x8's. You said measure from the rim to the fender right?
From the ground to the fender on mine is 36 inches with 265/75R16 tires. Basically the same as 31's. I had the Ranger lean so I cranked it up a little to even it out. It was just under 35 inches before I leveled it out.
Cool!:icon_thumby: Thanks dude.
If it helps, I think I'm like 36" to the bottom of the rockers.
But that's far from stock.
Well I just measured from the floor to the fender, it measure aprox 38" front and 38" in the rear. So I assume that the previous owner did crank the tbars. So I lowered it 1" so now I have exactly 37" front and 38" rear, 1 inch difference is good enough. Rides smoother NOW! Now I know what I have... Thanks Guyz.:icon_thumby:
