- Aug 4, 2009
CHI heads bit on Windors...the difference is a water port. However, they use different intake manifolds (the CHI is unique on the intake) and different header (which is rare an may become custom or semi-custom). Otherwise, pretty similar.
The net, at the Engine Master's Challenge, the CHI head is consistent winner against everything else and used by multiple top builders.
Also the low-deck block (8.2" vs 9.2" 351 and 9.0" Chevy) is easier to package.
Hot rodding Fords are common. FEs and small blocks windsors are widely used in Mustangs and Cobras. Cleveland was available down under much longer and that is where CHI is from.
In the end, from a performance standpoint, it may be hard to tell the difference on the street. A dead stock build, nicely detailed, can be satisfying.
