zukirider21
Alright, I gotta do a headgasket and and I'm wondering if I should clean up the intake and heads while im at it (using a little kit like the one from Standard Abrasives). Some people tell me that it's pretty rough in there. However, I know that the 2.9 is an impressive little motor from the factory (basically equivalent to half a 351 Lightning motor with peak power at a lower rpm) and is pretty finley-tuned as is. I also know that the 2.9 gets a little more air than it actually needs, and pulls best a little off of WOT. Now, would porting make that condition worse, or would it improve flow so much that I could possibly run a *LITTLE* bigger injectors?
Thanks
Thanks
