miss at idle and slight stall at take off
cadboy17
10+ Year Member
ive been having this problem for awhile and i figured ide ask some people who might know. my truck misses at idle and stalls alittle on take off and misses some times at cruising speeds. please help me out.
I had this problem for a while and eventually got a code, it was the coils. replaced them and it went away. Now I'm getting similar simptoms, boggy idle sometimes, and a stumble below 2000rpm, I have a feeling its time for plugs.
thanks ill have to try replacing the coils then
i had the same problem as you what me and my friend did is take the intake off and put throttle body cleaner in it...it doesn't stall or nothing no more i mean it worked for me and if it works for you i'd like to know but i hope i helped out a little bit
having same problem here, but it only does it when cold, i gave it some gas when she was cold yesterday and it stalled. I heard a pfffft, when it quit. After a bit more driving and it warmed up, throttle response is great, no off idle stumble. However, while cruising, i too get what feels like a misfire, but not completely. It basically feels like someone keeps tapping the brake randomly while I'm cruising. I'm gonna do some investigating. Did the coils fix your problem???
