- Mar 15, 2009
- Tallahassee, Fl
Ok, To first diagnose a starting/ charging system you need to understand the basics of the two systems. Let's start with Volts, Ohms, and Amperes. First a voltage is the amount of electrical pressure exerted onto a circuit(imagine the water pressure in you water hose). Now Ohms would be the resistance to that flow, for example the nozzle on the end of the hose. Last but not least the amps is the amount of flow itself. Now a hose with 40 psi and no nozzle has a lot of flow and no pressure, where as a 1/16th inch hole at the end of the same hose would result in a lot of pressure and little flow. Next well talk batteries. It is a chemical storage device that uses dissimilar chemicals or metals to create a voltage, and automotive voltage is 12.6 volts. You have 6 cells inside the battery making 2.1 volts each. Now you have a battery cable leading to one side of you starter relay, this cable has to be big enough to handle the amperage of the vehicle plus some on both pos and neg. of the battery. Now you have another cable out of the other side of the starter realy to the starter. I will stop at that and explaing the relay for the moment. A relay is a device that uses a lower current to control a larger current. Therefore you can use a low amperage from the ignition switch to control the greater current that the starter needs. So to control the relay when the key is turned to start 12 volts and a very low amperage it sent to thi relay via the smaller wire on the relay and it pulls a contact together inside the relay making contact between the battery wire and the wire to the starter making the starter turn. Now the last part of the staring system is the ground wire, which needs to be as big or bigger than your main battery cable to handle all the amperage in the vehicle. Now on to the charging system, which uses the ground and pos cables and the relay in a lot of cases. An altenator is an electro mechanical device that actually produces a AC current, but is turned to DC for use in vehicle by three diodes which are electrical one way check valves. Now earlier we discussed that automotive batteries are 12.6 volts, so to charge one an alternator must produce at least 13 volts to charge a battery, but not go higher than 15 volts in order to avoid damage to electrical control units. To avoid this there is a regulator that controls the amount of current sent to the windings to control the voltage. Now if you have a bad ground an altenator will tend to under charge, but is not always the case. If you have a broken battery cable between the battery and altenator the alt itself will put out as much as it can (i've seen 75 volts), but it won't charge the battery. Now that you have a basic understading of the systems, and if Mr. Jim Oaks allows me to I will do a write up on how to diagnose, what voltage drops are, etc. Hope this helps someone, or can get saved, and edited and whatnot.
