- Nov 25, 2007
- Age
- 41
Hello,
I have a '97 Ranger 4.0L 4x4 STX with rear-only anti-lock brakes (RABS). The yellow anti-lock brake light is on in the gauge cluster. If I start the truck with my foot on the brake, the light does not come on until after I take my foot off the pedal. I tried replacing the speed sensor on the rear differential, but this did not make the light go out. I did a little research and supposedly there is a test connection under the dash where I can ground the black/orange wire in order to make the abs light flash a code. I can't seem to find this connector, and was wondering if a '97 is different than a '96 and older setup. I did find what the autozone repair info. website said was an abs test connector on the front of the power distribution block under the hood, which has a red and a green wire going to it. However, I do not know how to activate the light to flash a code with this connector, and didn't want to start blowing fuses by experimenting. Does anyone know if you can get the codes by using this connector? Better yet, does anyone have any ideas as to what could be causing the light to come on? If the speed sensor that I replaced was the issue, would the code erase itself, or would it need to be cleared? Any help with this would be greatly appreciated. Thanks.
