The Rowdy Ford 97 2.3liter 5spd 2 wd, regular cab, step-side.
I got sick of my heat-shields rattling today, so I decided to tac-weld the shield/ the welder was a line feed, and wouldn't feed, tried fooling with it, checked wire, bla bla..... screw it I'ma take the shield off.
I used a 4in grinder, got the bottom shield off no prob, started my truck (rattle/rattle/rattle)
Began grinding the top shield off (i could see the weld cracks)..... then that pesky frame wouldn't let me get close enough to finish the job.
Out comes the good O'll Oxy/Acetylene......... things were going great, until I super heated the cat (being carefull not to burn my 02 sensor wires) then the torch back-fired, popped and blew a nifty little hole in the cat.
I finish the job, start the truck
icon_confused: how is it possible it sounds so bad?) like a screaching, farting Dirt-bike......
So the torch comes out again, I dropped the kitty
then the search begain for a piece of pipe (to get me through until the holiday is over and I can get parts) I found a man that has some exhaust clamps and a welder (just in case) I can use at 9am sharp tomorrow.
I found a piece of pipe of similar diameter and thickness (it's off an old cattle gate) i asked my boss, and torched a piece that was in the best shape (being carefull mind you, not to kill myself, burn the shop down or cause any more carnage)
My check engine light is on, and my truck doesn't even have the dignity of sounding like 2 3cylinders fighting each other as it is a Manual 2.3liter.
I definantly won't be getting used to this.
Frank
Frank
