- Apr 18, 2009
I just installed a used transmission in my '99 Ranger 3.0L 4R44E trans, reg cab, 2wd. After I drive about five miles the O/D lights starts flashing. After a while longer it starts to slip. By the time I got home it wouldn't go into D or R but moved when put into 1 or 2.
I made sure the torque converter was correctly seated (thanks to all the help I got here) and the trans to engine bolts all were easy to thread by hand all the way to the end. Nothing binding anywhere. I considered that the cooler and torque converter would require additional fluid which I had on hand. I originally added four quarts of Mercon V before starting the engine. I checked the level immediately and kept adding fluid until it was to the bottom of the crosshatches. After driving for several miles I checked the fluid and added enough to get it to the top of the crosshatches.
I read some old posts that suggested the problem might be the speed sensor. Well, this is a '99 and it has a DSS. No mechanical sensor. Also, someone suggested that the codes PO741 and/or P1728 might appear on a scanner but I could not find either of those codes listed on http://rockledge.home.comcast.net/~rockledge/RangerPictureGallery/DTCs.pdf.
So, is there any hope or should I try to get my old transmission back? I have not yet determined a way to read the codes because I'm not sure it will make it the 15 miles to the nearest trans shop and I don't have a code reader.
