- Jun 22, 2009
1996 Ranger Supercab 4.0 5-speed 4x4. The truck currently has 234,000 miles on it. At 152,000 miles the lower intake gasket gave way and I replaced it. Luckily It happened in my driveway getting home from the store. Since I fixed it the coolant level stays the same.
Recently the EGR valve diaphragm broke off so I had the EGR valve and pipe above the exhaust manifold replaced. My EGR solenoid was broke so I replaced it. I also replaced the DPFE sensor with the updated version. While doing this I also checked all of the vacuum lines on the engine for leaks. About a year ago I replaced the IAC as it was inoperable.
It runs rough seemingly when it warms up to operating temperature and throws a P0300 code. Occasionally it will also throw a P0301 or a P0305. Power is also down at highway speeds and fuel economy is down approximately 20%. Obviously it idles rough but it also doesn't quite feel right while driving at highway speeds either. I'm not sure how to explain it. There isn't really a hard miss, but a slight roughness.
I replaced the thermostat as it wasn't getting up to operating temperature this winter.
It has new plugs. Autolite APP105.
The plug wires check within specs with an ohmmeter.
I back probed the TPS and voltage is .93v at idle and around 5v WOT.
I also back probed the MAF sensor and it reads within specs at idle and at approximate road speeds.
For good measure I also cleaned the MAF. Twice.
Despite the fact the IAC appeared clean I cleaned it anyway.
The coil checks good on the primary side with an ohmmeter but slightly high on the secondary. The book I have says no more than 15K and all three of mine read 15.6K.
Vacuum at idle stays between 17 and 18 but dips 1 to 2 during the rough idle episodes.
Fuel pressure is around 28-32 psi.
I have not done a compression test as of this posting.
The truck, when started cold, idles around 1000 rpm for a few minutes then dips to around 800rpm. This is when the P0300 code appears, especially with the added load of the A/C compressor.
Does anyone have any ideas? Thanks.
