- Aug 24, 2009
P0301 = #1 misfire... P0305 = #5 misfire... p0300 = multiple cyl misfire or unable to define misfire due to cam position failure. During a cold start spray some carb cleaner around the intake gaskets if engine speed changes you have a vacume leak, intake gaskets will leak more when engine is cold. Next could be injector flow or spray pattern problems (dirty injectors). Least likely would be carbon buildup on the back of the intake valves. The carbon soaks up the fuel on cold starts causing engine to idle rough
