- Feb 8, 2009
- Omaha, Nebraska
Yes.
Yes, you'll have to slip it on the pipe, and measure how much you'll need to shorten the pipe, oh and make sure you use an adhesive to mate the two parts together when you are ready to install.
so buy like 2 feet of 3" diameter pvc pipe, slip the female part on, trace a line and then cut slightly less than at the line?
what kind of adhesive should i look for? a plumbers adhesive or something? i assume if i can find somebody at home depot or lowe's that knows the female and male parts that i need, they will know what kind of adhesive.. but i'm asking here just in case lol.
also to the a-5, how much mdf total is that box? i will be basically making the exact same box i think.
also to anyone, does it matter which pieces of mdf is going to be on the outside of the box?
like which pieces should be attached last and what not? i've heard that the front and the back should be the last two pieces to get screwed and glued down.
