- Jun 10, 2009
hi, my name is daniel and i just bought a 92 ranger xlt with a 2.3l 5spd 2wd. the problem im having is that it runs kinda ok when its cold or first started and drove. after about 30 mins for driving or i guess when it heats up it sputters bucks, no power, then pops and dies. it will start back up and sometimes idle for about 5 secs then sputters and dies. if it sits for a while it will start and run. i crack the trottle and it revs really good then gets hot and dies. ok, now for what work has been done. both coil packs, all wires, all spark plugs, fuel pump, fuel filter, fuel rail, injectors, fuel pressure regulator, crank sensor (but from a junkyard) the guy before me said he had put a ignition module on it but it looks as if it was one from a junkyard. iv cleaned the battery terminals and all connections. i even had the exhaust inspected and the muffler was stopped up. put a new muffler on it and it did good for about 2 days and now its acting up again. but i only made 30 -40 min trips at the most. now at work this morning i just went 2 mins up the street and now when i was coming back to the shop i felt the power loss as if i lost a cylinder or something. sorry for the long post but i wanted to give as much information as possible. i'v been working on ford for a while now but this has got me stumped. im leaning toward the original owner got a bad ignition module from the junkyard because it gets to hot to touch when it acts up.
thanks.
p.s. i did search a bit from google and this forum and their solutions are whats allready been done...any ideas...?
thanks.
