MAF, Throttle Body, and Chip
beaujt
Washington/Idaho
Ok, so i'm looking to swap out the MAF, throttle body and slap a jet chip or something from James Duff on my truck. I was wondering mostly about the MAF though, where can i get a replacement one that will help to boost the horses in my truck? I've already put an intake on it, and its a 93 ext cab 4.0L automatic.
I've found the throttle body(BBK) and the chip from JET and it looked like James Duff makes one too... so i think i'm set on that, unless anyone has any suggestions?:icon_cheers:
haha this is in preperation for boost :) I'm working on getting to the point of putting either: a supercharger(gotta find one first!, single turbo, or twin turbos)... all of which basically require me to rebuild the motor first... sucky but i wanna do it right! :D
twins are soooooo not nessarry maby look into headers and exhaust
hahaha i know, its gonna be a while before i even get to any form of forced induction. but next on the list of things to do is exhaust and headers... along with 8" SJ lift and 35" tires/or SAS swap. I'm just doing stuff when i can, and still being able to pay for school too:dunno:
www.zabteck.com has 4.0 parts and I think larger MAFs.
well it checked them out, and it looks like they specialize in later model 4.0L Like the SOHC motor mostly. Can i get the MAF in there right now, machined to let more air through, or would that be a bad idea?
maf and injectors
try a 2000 lincoln mark 2-8 for 26lbs. injectors and maf. that is what i am going to use.
i would wait to change the maf and such till you got the super on it you'll get a little more power but may run way rich or have other issues arising but not an expert. the chip will help now thoe.
:headbang: WHOOT!!! TT aaall the way! :icon_hornsup:
where are you getting the injectors at? i've heard of guys using different injectors from mustangs too.
the injectors from a lincoln mark 8 are 21 lbs btw and the maf is built into the filter box but can be easily changed that is what i am working on right now getting all the tuning for a blower. not so easy there aren't many options none of them good ones
about the chip. I saw someone on here tried a Jet chip and it didn't do anything what about the James Duff chip. its 300 bucks, twice that of the jet chip, anyone every use it? does it work?
Bamachips.com
I know that Jet also makes a MAF and was going to get one, until I called SuperChips (I have their Cortex) and was told NO-NO-NO. An aftermarket MAF is not friendly with their programmers. As for Jet's chips/modules - I have heard little good about them, but a lot of bad.
how much would a new MAF help really?
i have never been able to find a programmer for the OHV since it isnt OBD II. ive only seen the Jet chip (havent heard much good either) and the james duff one. i thought i read somewhere that some of the OHV motors came from the factory not able to use a new chip. something about even with a new chip the computer would ignore it and run stock or something? maybe im wrong but im not sure.
